1 - 18 of 18 Posts
I’m in the middle of doing a LQ9 swap and I’m wondering what everyone is running for a MAF sensor? I do need to run one correct? For the engine to operate correctly.
Depends on tuning setup, you can run a speed density tune with just a MAP sensor which is very common in turbo setups, most people run the maf sensor that came out of the vehicle with the engine.
Generally speaking a "MAF" tune is better for every day driving. It enables you to run open loop with feedback from your o2 sensors and airflow readings from your maf to optimize fueling.
Well, it appears the new forum will not allow me to attach .hpt or .zip file. That's a bummer. Truck is a LQ4, 243 heads, LS6 cam, TBSS intake, 92mm TB, LS7 MAF, 4L80E. Here is a link to the most recent tune on my google drive: https://drive.google.com/open?id=13H3KKv4kyb5qe9azpKfn1mer2w2IdpSO
To use the LS7 MAF you need to move around a couple of the five wires:
A- Yellow
B- Black/White
C- Pink
D- Black
E- Tan
What would be wrong with running the LQ9 MAF on an LQ9? Since the OP hasn't mentioned any mods to the engine, I'd think it would be the best one.
It's the same sensor used on 5.3's the same years, 99-06. It includes the IAT sensor.
LQ9 MAF (truck style) is bulky and expensive. Depending on intake plumbing, it can be difficult to find an appropriate location. The LS3/LS7 card card style MAF is only $30-$40, and can be installed in intake plumbing of virtually any size without creating a bottleneck.
Randy
Please share a part # for the card style MAF.
I'm trying to decide on cable or wire style throttle body.
Discussion Starter #11
The engine is a LQ4 with LQ9 flat top pistons, gen IV Rods, 243 heads, TBSS intake, 92mm TB, tick performance stage 3 cam, 60 lbs./hr injectors
Sounds like street legal race engine. Definitely not a DD.
Randy
I looked at the cam specs. I am curious/interested in why 60lbs injector choice? I am considering 30lbs injectors and my cam choice is slightly larger with the Elgin E1839P.. Maybe I just dont understand the whole fuel/throttle body size thing. I'm just a trans builder and not a performance tuner guy...
Discussion Starter #14
I’m still new to the LS game so maybe my injector choice may be a little large. In the future the truck become forced induction of some sort. I still have 2 sets of stock take out injectors, one set from a TBSS and the others are from a 01 6.0 III truck.
Randy
Same here. New to the swap gig that is. Thats why I asked. Thanks for the feedback.
The larger injectors are helpful if you add a cheap flex fuel sensor and want to run e85. Your LQ4 is similar to mine with higher compression and a bigger cam. I'm running the flex fuel 50lb injectors and only hit 50% duty cycle with 93 octane fuel, so I have headroom for e85, or about 9psi of boost. With your build, you will be beyond the flow of those truck injectors for sure, the TBSS injectors will be OK, but give you no headroom. I think the 60lb injectors are a good choice. here's a good calculator: https://fuelinjectorclinic.com/flow-calculator
Randy
Thanks for the info. Based on that calculator I'll need 31lb injectors for 450hp at 80% duty cycle, 28lb injectors at 90% DC. So my head calculation was in the ball park for my L33 swap.
Another thing to consider is which connector is on the injector, body size, and price/availability. I went with the following 50lb injectors because they are a factory reliable injector with accurate data, e85 compatible, stock truck height, EV6 connector (cheap to adapt to my EV1 harness), and very affordable. My current call is inline with yours, 450hp 93/E85, so I could have gone with a smaller injector, but these were the best deal and I have zero issues with them.
https://www.glennsautoperformance.com/collections/view-all-products/products/new-set-of-8-delphi-50lb-truck-height-fuel-injectors
1 - 18 of 18 Posts
