Like a Rock
LT-1. You won't need to have a custom pan made for it and it'll practically bolt right in (with the typical small block swap techinques)
Like a Rock
Check out www.V8S10.org. I talk with one of the guys over there quite a bit, they'll tell you how much headache you'll have. They'll also help you out with just about ANY small block question you have.
weatherman
well, i'm in the progress of putting an ls1 in mine right now. oil pan is an issue. you can use one from a 5.3L if ground clearance isn't an issue but no matter what you'll still have to cut the crossmember. there a a lot of other issues that goes along with it. the benefits are there though as mentioned above. talk to PEKO or sham or look up their threads on the ls1 swap. sham is making a book on how to swap in the ls1. you should buy it if you're interested.
