Two tones of terror
Ok, so im finishing up with putting on all the parts required to use a LS6 intake on my 5.3. I bought a new rebuilt LS1 water pump to use and the pulley sits way too far in to use with the 5.3 accessories. The pulley is pressed on, and I have heard elsewhere that I need to pull the pulley out some to get it to line up with everything else. My question is what should I use to slide the pulley outward? This thing is stuck on tight.
Two tones of terror
Im not sure. It's got the big round, wide pulley and the auction said LS1/LS6. Would it make a difference?
Need LSx swap.....
yea, the LS2 water pump has a narrow/flat pulley. youd probably have to use some sort of puller to get it loose and/or move it.
