Once those bolts are removed you can pull off your backing plate, heres what you get...
To put the new disc brake backing plate you need a thick washer (or I used 2 small ones) around each hole. The new backing plate does not sit flush because there is a small raised portion around the center, and needs washers to sit flush against it...the ideal solution would be a full shim around the entire area to get full contact, that might come later though. Install the new backing plate...
I installed them backwards with the left on right and right on left so the calipers were toward the rear of the truck. I thought this made more sence for when I get the parking brake installed because the lever can be pulled toward the front of the truck, instead of backwards if I installed L on left and R on right.
Another thing to mention is you need longer bolts to bolt the new backing plate on, its thicker than the old one and the washers make it worse. The camaro bolts will work because they are longer than the stock ones, these are pink in the photo. I also used loc-tite on them.
Somewhere around here I rigged up the used camaro brake lines to the T fitting, ghetto rigged it for now and hand bent the lines (hope they work). Later I will make new lines. You cant use your old lines because the flare from your line going into the wheel cylinder is different than the one you need going into the rubber line of the new caliper (thread is the same though). Options are to make custom cables, or the ghetto way and just bent the camaro lines.
This is all I have for tonight, im tired and didnt finish cause im beat. What you dont see is install of axles, diff cover, swaybar (which kicked my ass cause i was tired, Is very hard installing this tired and upside down, my neck is killing me.) I have the left side rotor and caliper/pads installed on the left side but no pic, I will finish tomorrow with more pics.....
