so.....only a select few on here can work with it anyway.....LS1-edit works with 1997-2004 LS1 car engines, 2001-2004 LS6 engines, the 1999-2004 LS1 truck variants: 4.8L LR4, 6.0L LQ4, and 5.3L LM7, 2001-2004 8.lL L18, 5.7L L31 and 4.3L L35 V6, and 2002-2004 6.0L LQ9 and 5.3L FFV
Go look on your firewall, directly in the middle of the truck. Or look in your glove compartment.Rick X said:quote:
and 4.3L L35 V6...
What's a "L35" ???
Which 4.3 can you use LS1 Edit with?
Mines a '98 Sonoma.
This is what I see (2001-2004 8.lL L18, 5.7L L31 and 4.3L L35 V6)j_gor78 said:It looks like you can only get the software for 00/01 that doesn't seem right???
lolxtreme2299 said:Then you can't use it.....99 is not between 01-04.....
Maybe you can just swap your engine out....?????
