I have rear discs from an f-body with a silverado ss master cylinder. I want to know if there is an adapter to connect my hard line straights to my calipers because I have bad line flex.
You're trying to go from your truck hard line to the LS1 rear calipers, right? Do you know what type of fitting is on your truck's hard line? I expect it to be a 7/16" inverted flare but I'm not sure. Let me know what you find out, we can get you hooked up with the right lines.
Ed
The caliper has a banjo bolt that goes to it but I am not sure what the fitting thread is on the s10 brake hard line.
