21 - 27 of 27 Posts
· Been there Done it
Mostly mine own fault it's taking too long. I was aware that the first LQ9 I had bought wouldn't turn 360° by hand. Tore it down and found #6 connecting rod bent. Replaced it with a new one and put a new injector on that cylinder figuring the injector must leak and caused hydro lock. Started it up when the swap was completed and the engine literally exploded. Both 7 and 8 rods were gravel and a piece went thru next to the new starter ruining it and the block.
I then bought an 05 Gen4 LQ4 since LQ9's were hard to find. Put it in and it started ticking. Pulled it out to find #8 rod was bent, just a hair and the piston was just scratched by the crank. Gonna put the new rod from the LQ9's #6 in the #8 piston and will clean up the skirt with a file. Then sell it on Facebook Marketplace. My idea of pay back.
Bought a 3rd engine, another LQ9 from LKQ and started installing that when my mind ran out of gas and I took last summer off from it. Just last week got it together using all the injectors from the 05 LK4. Going to do an individual injector test with my Tech2 and a fuel pressure gauge before firing this one up. But the bottom just fell out of he thermometer and I'm not going to work on it until it warms up. No fun, even with a space heater in the shop when it's single digit highs. I can only just get it up to the 30's inside when it's that cold. A 20° gain when it's in the 30's I can handle. At my age 50's is about the lowest I can tolerate for long. I also don't want to start an engine that has sat over a year when it that cold. I think temps in the 70's would be less apt to cause unnecessary wear.
LKQ gave me a 6 month warranty on their LQ9 and a copy of the accident report verifying the miles on the motor and a pic of the rear end damage to the Escalade. So there's no doubt it's a good engine.
May probably.
That's life here in the Frozen Tundra. Stay inside from December thru April by the fireplace.
@oldeerslayer
I hope you are joking about “my idea of payback”. I didn’t have you pegged as someone that would sell anything you think is shady in any way. You’re one of the guys on here here whose word I consider S10 gospel!
Much better to payback the person that screwed you than to pass it on to me ( or whoever the person is that ends up with it). Better yet sit back and let karma do the work.
Mostly wishful evil thinking. Meant more as a commentary on Facebook Marketplace. Have had nothing but bad luck with any parts I've bought on there, but it's nearly killed Craigslist around here.
I'll probably fog oil it, shrink wrap it and keep it as a spare since I have 2 trucks with LQ engines now. Got an L31 and L33 already stored in the shop. I found that with a couple short 2x4's and a piece of 3/4" plywood a spare 4L60E will slide onto the engine stand below a V8 or 4.3. Thus being able to store both an extra engine and trans using the same space on the shop floor.
Actually once I put the new rod and bearing in it, it will be a good engine. It's a 125K, if I believe the seller, that simply needs a rod and those 05 LQ4's use the newer floating pin rods. All LQ9's from 02 on used the same Gen 4 rods. The small scratches on the piston are just light marks where it was just brushing the crank and are so low they never enter the bore. Or just barely do. It's the very bottom of the skirt. Only has at most 1/2 hour run time and only at an idle. Tore it down soon as I heard the faint ticking. I have an extra set of head studs and gaskets for re-assembly of the long block.
Might use the 799 heads off my L33 and make it a LQ9 the hard way. Dished pistons and smaller 65cc combustion chambers. Instead of the factory flat tops and LQ4 71cc heads.
21 - 27 of 27 Posts
