I doing my first LS swap in to an 88 S15. I picked up a set a set of Trans Dapt motor mounts /w pads. Realized that I needed the engine to sit lower in bay so I followed the instructions to cut off part of the mount. Now my mounts no longer actually fit with out lowering the mount pads lower in to the cross member, adding spacers between the mount and engine and hollowing out the solid mount so it fit to the pad again. Turns out I got an old set where the ears on the mounts are higher up then what trans dapt sells now, does anyone have the dimensions for the new mounts? I got some space flat steel and want to weld new ears on mounts.
