That would be dependent upon an individual's perspective, circumstances, and criteria, so for some folks, all 3 can be had.Chasing HP is usually a never ending pipe dream that saps all of your time and money, I just want affordability and reliability. You can't have all 3
Boost level for stated output will reveal this combo's potential.
Cadillac is not having a problem with it. I considered it but for my needs the 2.0 was good enough for me.I see that 2.7 engine being a recall nightmare. They have so much going on and very little wiggle room for when stuff does go bad. Should make it 36k maybe 60k after a few service bulletins. Of course most 5/60k warranties are vague on if sensors are covered.
Make for a great lease that you don't modify or do anything to besides very basic maintenance. But as far as a junkyard engine that your going to need to run stsndalone in a s10. I feel you have better options.
True That. LS design cyl head design proves that out in spades.........When I was a teenager I worked for a man named John Stewart he owned Magnum Plus Nitrous in Houston Tx. He told me, " your engine is like your relationship if you don't have GOOD HEAD it will not be beneficial" that holds true
Fer Sure would have to be a 4" bore to keep valves from clipping cylinder wall (with shown Sq port LS head.)I saw this on the PRI Instagram.
I know nothing more of it, but, what a great combo.
If this comes to being a crate engine or easily obtainable, what an awesome swap potential..
i know there are better options. I just think an engine that was designed from a clean slate for trucks and with turbocharging would be a great engine to swap into my S10. I would like to keep a 4 cylinder and it would be different from everyone elses. The engine bk2life introduced would be Great also! But would I be able to find one of those in a wreck anytime soon?I see that 2.7 engine being a recall nightmare. They have so much going on and very little wiggle room for when stuff does go bad. Should make it 36k maybe 60k after a few service bulletins. Of course most 5/60k warranties are vague on if sensors are covered.
From what I read , it's a prototype block Blueprint Engines is considering for crate production that uses an LS head. Probably won't be bargain basement, but @ 3.7L , it'll be a fun torquer. Reminds of Pontiac 1/2 389 V8 4cyl engine used in 60s Tempest with transaxle rear end. Star in movie "My Cousin Vinny"i know there are better options. I just think an engine that was designed from a clean slate for trucks and with turbocharging would be a great engine to swap into my S10. I would like to keep a 4 cylinder and it would be different from everyone elses. The engine bk2life introduced would be Great also! But would I be able to find one of those in a wreck anytime soon?
Thanks for block source clarification. Begs the question of how cyl head squaring to bores and attachment points were dealt with. Robust Dyno results would suggest this is a viable combo if adaptive costs are low. Did look up Origin 3.6 but didn't recognize block.Origin sells it with a 302 FoMoCo cyl head, hence bolt pattern similar to LS. It's the largest 4 displacement I've heard of . Porsche had a 3L in 944s . Other Origin engines appear to be modified GM sbc and bbc units in visual inspection. Blueprint and Origin apparently in same Corp unit. So this prototype may happen.the 3.6 L inline-four is based on a industrial motor built by Origin Engines for Kohler generators
