LS Current Performance Base Tune
1854 Views 14 Replies 7 Participants Last post by  EZA
I have a 5.7 LS1 with a Current Performance ECU/harness. No big power adding mods have been made to the engine. I don't know a whole lot about tuning so I don't know how much of a difference a professional tune would make compared to the base tune the ECU came loaded with. Does anyone have any experience with this? Should I leave the base tune or would it be worth the $300+ to get it tuned?
1 - 15 of 15 Posts
It'll be worth the money. Especially if you can get it dyno tuned for that price. If it's not on a dyno, keep your cash. Mail order tunes are a shot in the dark.
1000 million times worth it to have it fully dyno tuned. Don't use some cheap $300 mail in tune either. There is no way those are 100% correct for your vehicle. They'll get you close, but you could be missing 50hp for no reason. I do tuning. But I still have my tunes put on the dyno for the final runs so I can 'see' what's going on. Expect to pay at least $600 for a good reliable dyno tuner. My last tune, less then 45 days ago, was $750.
I have a guy that said just $350 for a Dyno tune... Interesting.
Thank you for your input though. I really didn't know, so I'll definitely be getting it tuned.
A base tune is just that, it will get it started and running. Probably have a few things deleted, security turned off, and not much changed in the actual tune performance wise. Go with an actual dyno tuner to get it done.
I can't see you gaining that much from what you say is a basically stock engine. Think of it as hp per dollar spent, $350 ok, $ 750 hell no!
I picked up 75hp...I'm sure there is more waiting to be unleashed. It's running pretty rich right now so I'm goin g to take it back for a few adjustments.
It is hard to believe you pickup up a 75 hp gain on a stock L33. I did a search and most guys were saying 15 hp with a stock engine. Was you gain after adding LS6 intake, dual exhaust etc?
Well....I have no reason to lie. I'll see if I can find thee dyno sheets.
Well, if you’re cheap, I can understand that. But nowhere in my sentence did I say I paid for a stock engine to be tuned. And I’m not belittling you, merely stating the fact that things cost differently in various parts of the country. Also, labor costs money, $750 for a full day of custom tuning is actually pretty cheap. But, again, were not talking about stock drivetrains here.
You did a search? The guy literally told you how much he gained, and he has the dyno sheet to prove it. But, the internet says no, can’t be true, so it must not be. Again, not belittling you, but, you should spend some time at the local dyno shop and make some friends. There is a reason good, reliable tuners can get what they do from stock combos. The factory settings have been proven to be underrated to make a 100,000 mile warranty last.
I'm only telling you what I found after doing a search on the internet of various stock V8 engines. Specifically a 5.7 Hemi and an LS1 by the people that owned them. Here's a link to typical articles I found How Much HP Can You Gain From a Dyno Tune? | Car Performance Boss
But consider that I have a lot of supporting mods to make the swap work, like a custom intake and catless exhaust. I think I have 20-30 horsepower hiding in there
I agree, and Rhotpursuit's L33 has free flow exhaust, LS6 intake...but I was referencing a stock 5.3. I find it hard to believe the factory would leave 75 hp un-tapped.
Gents, I am currently using the base tune from current performance. I have a 1993 s10 with 6.2L/manual from 2015 camaro. I used current performance for their wiring harness, which is top notch quality. Since they were building such and I need vats removed etc, I decided to let them do the base tune as well. To date, the tune has worked great. Not saying I got peak hp, but it starts and purrs like a kitten cold or hot. With stock motor, I have plenty to spin the tires thru the gears.
Now, I do have Hooker midlength headers, CAI, and hooker full exhaust. Not sure if a custom tune will gain me much??? (if anyone has similar such, curious what hp they got)
But to date , I am happy with such. Keep in mind, I build this truck in about 2 months or so......
Just my input gents....
Reactions: 1
@jeremywilliams8, Sure the more mods you have the more you'll gain from the tune. This whole thread got off on the wrong foot because I was referring to a bone stock engine. Rhotpursuit has mods, like lS6 intake, free-flow exhaust. cold air intake etc. so he would see hp gains with a tune. Tune a stock 5.3 all day long and you're not going to gain 75 hp.
1 - 15 of 15 Posts
