1 - 20 of 20 Posts
I have polyurethane motor mounts not the 2.8 style I feel that my motor sits to high transmission is in stock mounts on crossmember motor look s level but alternator hits on hood and intake hits on hood too
2000 gmc Sonoma short bed single cab
5.3 out off Yukon 4l60e transmission h2 oil pan and eBay motor mounts
Car Vehicle Tire Hood Automotive lighting
Automotive tire Motor vehicle Rim Auto part Engineering
· Been there Done it
The front is definitely too high. What brand and part number upper and lower mounts are you using? What engine was originally in the truck?
i tried to get a simaliar shot of mine to compare to yours. Yes mine is heavily modified, but, i think your issue is more of engine tilt. I think youre trans is too low causing thefornt to come up. Mine is an hombre, i think the hombre hoods ar e bit lower then the s10 hoods, my 5.3 fits under the hood.
Tire Wheel Vehicle Automotive tire Hood
id redrill the holes in those motor mounts they push that engine up high.
Also, that oil pan will hang below the crossmember, and thats a nono for a lowered vehicle having an aluminum pan hit the road isn't good.
roughly how big is the distance between your dampener and sway bar?
Automotive tire Wheel Tread Motor vehicle Tire
On my Escalade 6.0L swap I wanted enough room to for the 2002 Caddy top engine cover to fit. I wanted the "Made Exclusively for Cadillac" to be visible. In 02 only the Escalade had an LQ9. Chevies got it 03.
So I modified the engine portion of the Fleabay mounts to lower the front of the engine. Surprisingly is created more room at the rear of the crossmember. Now there's nearly 1/2" to the pan at the back of the front crossmember. And the pan is about 1/2" above the front of the crossmember. If your pan is farther away there is room to go down. I think BK is correct that you might want to put a different rear mount that's taller in there. I have a 4L80E so I can't help with which one to use. Maybe one from a 2wd Silverado 1500 with a 4l60e? Or you can cut a plate of 1/4" or 3/8" steel to put between your trans mount and the tail housing. Use a stack of washers temporarily to find the best height. Or simple stick a piece of 1x2 in there to see if it cures the problem. That's 3/4" thick. or try a 1/2" plywood scrap.
Here's a Photoshop image of what I did using your pic.
Automotive tire Motor vehicle Bumper Automotive exterior Gas
· B4U Task Force
It doesn’t hang below. It’s a Holley white box pan.
Best pic I have. If you enlarge it you can see how far above the crossmember it is.
Tire Automotive tire Mode of transport Motor vehicle Fender
03 GMC Sonoma SLS & 04 Chevrolet Blazer Ls
my Passenger side header is already close to the upper control arm if I lower the motor any more it will hit
1 - 20 of 20 Posts
