I have a 2000 Xtreme reg cab and want to lower 2/3. What exactly do I have to buy to do it right and not lose handling performance? Anyone's help is appreciated.
is the way to go, because ZQ8's already have 1.5" lowering coils and leafs. as for the handling part lowering your truck improves the handling because it has a lower center of gravity therefore stays planted better. and the ride will be the same as stock because the suspension geometry is not changed at all.
Yep spindles & block are the way to go. I just did mine.
It handles better than before & rides just as good as stock, but you will have to cut off the bumpstop brackets in the back or you will be hitting them all the time.
