1 - 14 of 14 Posts
Ole skule VW nut
2/4 drop, which is best? 3" leaves with 1" block or just do the 4" pinion block? Either way ride better? Not talking cost, just ride. I had heard you lose hauling capacity with the leaves, but I don't really haul anything much anyway.
What is your opinon?
SuperFly
3 inch spring and 1 inch block. the ride on teh springs is better imo. also, you might wanna consider a different set of shocks for that drop.
bagged1
The leafs look better, and are probably better perfoming than stock leafs with 4" blocks.
Although they are more expensive, they are worth it.
Ole skule VW nut
grndscrpr03 said:
I would go with the 3" leaves and 1" block for sure. Putting 4" blocks on stock leaves rides like a logwagon. You'll have back problems after riding in it for too long. The leaf springs gives an almost factory ride.
Thanks for the tip. :bowtie:
dubdS10
Anybody in their right mind and can could afford it *SHOULD* pick leafs and a 1" block over 4" drop blocks.
They may be more, but are well worth it.
Nate
footbraker
How does a block alter the ride quality? The spring rate doesn't change - is it related to the shock travel?
HUHH
i tryed leafs, they road like ass it was hella bumpy an kept bottomin out. bought 4" angled blocks an rides 100x better. i figured maybe just because my truck but. my firend also same think when he bought leafs
dubdS10
Blocks will lower raise the axle up closer to the frame, so it will hit it hard if the bumpstops aren't removed, which many people don't do. I had a fine ride with 3" coils and 3" blocks on my '94 after I removed the bumpstop brackets. But I wouldn't run 4" block..just don't like the idea of that tall of a block holding me up.
Nate
FATDADDY
audiodog with the 3" coils in the front did you change the shocks? i have a 96 straight cab and was going to do 3" coils and 3" blocks what kind of ride is it and do i need new shocks??thanks
dubdS10
Technically, yeah you're supposed to go with drop shocks. I never had shocks installed cuz I didn't have the cash at the time and then sold it a few weeks later anyways.
But my ride was perfectly fine and it handled like a sports car going around corners. But that was with X rims and 50series tires.
Nate
Ole skule VW nut
Discussion Starter #14
But the leafs do not affect the pinon angle do they? Will I have to use shims if I run just the leaves?
1 - 14 of 14 Posts
