anyone have any pics of the mods that need to be done to lay out on 20s. I have 255/35/20s and having a hell of a time laying completely out. Thanks to all.
cool thanks for the pics!! i first cut the humps off, tried it, cut the frame for the tie rod, tried it, cut by the rear bushing on both sides because it was hitting too. thats where im at now. i need to put them back on and make sure, then weld..weld..weld. thanks again!! brian
VVVthat thing is deadVVV
you also have to pie cut the uppers for 20's. i believe it's 13 degrees? cut a slit in the underside of the upper right behind the balljoint all the way up to the top on both sides then bend the balljoint plate out until you get the right measurement and weld in a brace
