99 Chevy S-10 4.3 K&N cold air intake, blackwidow venom 250
did it do this before the changing of parts?getting 15 psi of oil pressure
No, before it started right up, now it takes awhile and yesterday I started it and the noise changed from pistons to valve train and the oil pressure has gone from 15-20 to 40did it do this before the changing of parts?
thats not what i asked.
That kinda sound is Expensive.did it do this before the changing of parts?
did it have 15 psi of oil pressure before you changed all the parts....
Wandering Oil Pressure ? I'd run a quality mech gage to verify beforeThe only thing that could affect oil PSI is the oil filter.
Id change it just for peace of mind.
If you have the dist in worng it wouldnt run.
there is zero anything else you did that would cause oil psi problems.....DID YOU leave a rag in the intake valley?
Actually, there are several other possibilities; one example could be improper bearing clearances. But, based on what the OP has stated so far, I'd suspect something else before that.The only thing that could affect oil PSI is the oil filter.
true, but, he R&I the intake, which wouldnt effect the oil psi at all.Actually, there are several other
As a GM tech , I picked up 2 pristine 454 blocks from metal discard bin , warranted for Main brng knock. Actual cause was defective mech fuel pumps ! Thanks to 'jump to conclusionstrue, but, he R&I the intake, which wouldnt effect the oil psi at all.
He did an oil change, so in THIS scenario, the oil filter is the only thing which could effect the oil pressure.
A possibility here is the oil cooler itself expanding under pressure, thereby acting as a sort of pulse damper. Think : old or damaged brake flex hoses that then expand , reducing brake line pressures and brake efficiency.I had trouble a few years ago with the oil cooler causing low oil pressure. I removed it and put the oil filter directly on the engine. I gained about 10 PSI.
