Lost my front drive w 4x4 hi and lo. Did find vacum hoes not conected and cant find were it goes like canister orb.
But tried put a skrew in hoes end and got my 4x4 drive back :) Its were the skrewdriver is pointing in pics.Can it dammage anything if I drive like this? till find out whats truble.
Have vice grips manually pull the cable at the actuator too right now..
Any ideas what to do next.
Discussion Starter · #2 ·
Did remove wise grip from actuator and 4x4 hi lo drive still works :)
Start to belive this vacuum hoes was pluged before but "plug screw" must fallen off.
4x4 v6 blazer
Should go to a vac ball or cruise control being the area its in. On second gens the vac ball was bolted to the hood I think. Could a PO have taken it off and just plugged the line?
ok thanks, I try if my cruise control works.
Cant see any use for vacuum ball othervice?
So guess its removed and hoes plugged.
4x4 v6 blazer
It stores vacuum and helps anything that runs off of it operate faster when the engine isn't producing as much. Stuff will still work but might take a hair longer for the 4x4 to kick in or the HVAC blends doors to move and such.
