What year is the truck?
That's a real good possibility the last parts truck I bought when I pulled the front bumper off I found a key wired inside of the hole of the frame think the original owner forgot about it look like it was there for decades it was totally black.Have you looked under the truck for a hide-a-key that somebody forgot about? I have had that happen twice, saved my butt!
You might consider (at least) pricing out what a locksmith would charge to re-pin your existing door cylinders (you take them to him) to match the new key, it might be $ well spent.I ended up getting a ignition off amazon and forcing my old one into startposition to remove it with screwdriver and a couple picks to get it out took some meesung around but it eventually came out. Popped the new ignition in and it started right up. I think im going to go to the scrap yard for a couple door cylinders and see if I can get the proper pins to rekey mine to the igniton key. Should be cheaper that using my ama as im out of service calls until April or March sometime when it renews.
Glad you got it working.I ended up getting a ignition off amazon and forcing my old one into startposition to remove it with screwdriver and a couple picks to get it out took some meesung around but it eventually came out. Popped the new ignition in and it started right up. I think im going to go to the scrap yard for a couple door cylinders and see if I can get the proper pins to rekey mine to the igniton key. Should be cheaper that using my ama as im out of service calls until April or March sometime when it renews.
