I tried to take the tension off my 98 s10 2wd by rotating the belt tensioner, but the bolt just broke over (like it was being removed). Anybody seen this problem? It looks like there are grooves for a special tool. Is there a trick to this I'm missing?
thanks, Bear
You dont loosen the bolt. You use a 3/8 rachtet . Look on the tensioner and you will see a square 3/8 hole. You put the rachtet into the hole and the whole tensioner will lift up. It will be hard as your lifting up against a strong spring. Bob
95 S-10 2200
I recomend using a breaker bar if you have one,3/8" but a ratchet does just fine as long as you get the ratchet locked in the right direction
Big Woops, I was attaching to the bolt on the pivot point, not the 3/8" slot at the idler. Thanks for the help. Just when you think you've got it all figured out, you do something stupid like that. Bear
I just changed out my altenator, and that is how I did it..
