1 - 2 of 2 Posts
DILLIGAF
I have found the bracket kit on Ebay but I can't see paying $215.00 for it. All I need is a template and I can cut it out of steel at work. Does anybody have a template, measurements, etc. for one they could send me or tell me where to get one?
346637
98 2.2 Extended cab, 2001 V6 Extended cab Sport Suspension, 2001 V6 Extended Cab 4x4
I take it you do not build scale models...
With the pic you show here, you should be able to fabricate what you need. The holes are 3/8" or 10mm, that would give you a known measurement that you could use to map out the rest of the dimensions then get to cutting.
Another idea is to take this for a starting point, and which ever alternator you plan on using as the second and use it's case, and some cardboard to make a template. To me though this looks like it is missing a couple pieces... just sayin.
1 - 2 of 2 Posts
