i got a 99 s10 xtreme and was wondering how it was dropped in the back with the stock drop either spring or leaf
LS6 swap in progress.
1999 LS6 Sonoma on C5 Brakes
i think its a 2 or 3" drop spring. the spring rate is probably a little different too. check the suspension forums.
AJ
The doctor is in...
The Xtreme has the ZQ8 suspension package. You get front & rear sway bars, different shocks, coil springs, and rear leaf springs. Your rear end is about 1.5" lower then stock. If you want to go lower, then swap in some 2" drop spindles and 3" blocks in the rear.
