Premium Member
I am looking to swap the exhaust starting from the muffler back. I will be reusing the stock tail pipe.
currently I have these items on my list is there anything more you think I need to complete the setup.
2 1/2 Inch Exhaust Clamp x3?
Stainless Steel Flex Pipe Exhaust Couplings With Pre-Welded Mild Steel Extension 2.5" X 8" -12" Overall.
2.25" ID 2.5" ID Universal Exhaust Pipe to Component Pipe Adapter Reducer Kits Reliable 2.25 Inch to 2.5
2 1/4 inch exhaust clamp x1?
Flowmaster 942551 2.5In(O)/Out(C) 50 Series Df Muffler
if there is anything else you think I am missing or should have, I would appreciate the input.
Seems like a lot of work. What's the cost of your parts, and can you install them yourself? Sounds like some welding will be required.
Premium Member
about 200 bucks so far for everything I listed. I was hoping to avoid welding at this point and use adaptors and clamps for now. the wrenching part of it is no big deal for me but, I draw the line at welding.
time to get cereal
A muffler shop would probably charge you less than half that.
2004 Avalanche. 2001 V6 Extended Cab ZQ8.
I had a single in dual out muffler and tailpipes made for just a bit more than the $200. Professional installation, and nice welds all the way through.
Flowmasters patent ran out a few years ago, so there are plenty of knock-off brands that go for around $30 dollars, and they sell them at autzone as well. but for a muff back system, cant be much more then 50-100$ at your local exhaust shop. And while you're at it, probably have them do a cat back exhaust for a little more, and you don't have to do anything, and spend the same amount of money that you are thinking of spending already..
