1 - 2 of 2 Posts
I just installed clear corners, they both blink but only the right one stays on steady. Also, my only my right highbeam comes on. I'm not sure if this was happening before, I never checked. I don't have my DRL fuse in, if that makes a difference.
Also, I used the right key to undo the top screw and it got stripped pretty good anyways, and the second adjustment screw got really stripped, did this happen to you, if so what did you do to fix it?
Thanks
NSOFL
1 - 2 of 2 Posts
