i have a 2wd s10 and i was wonderin how to make the front end set level with the back and not spend to much money. i just dont like the way it looks and i really dont want to lower the back end, b.c lowerin trucks i pretty stupid in my opinion.
is your truck a 4 banger or a v6?
- if it is a 4 banger, then you could buy a used pair of v6 springs off one of the guys on here. the v6 springs should make the truck sit about 3/4" - 1" higher.
- another option you have would be to buy 2 of the belltech spring spacers and install one on each side, on top of the factory springs. these would raise the truck about 1" no matter if it is a 4 or v6.
- last you could go and buy a true lift spring, or lift spindle. I believe it fab tech that make a 2" lift spindle, and 2" lift spring.
how much lift did you want to get out of the front? and also you will need a new alignment after you lift the front.
so in that case, id install a set of stock v6 springs, and if those still dont give you enough lift, add the spring spacers, one to each side.
Insert witty remark here
Have fun gettin them v6 coils in there too even with a spirng compressor you can barely compress them enough to bolt everything up.
