1 - 11 of 11 Posts
overthinker extraordinar
Hey Folks,
I am pretty sure I know the answer to this question, but thought I would see if I can get some confirmation.
My motor runs just the slightest bit off. It his a mild miss, maybe two. I can hear some lifters clicking a bit excessively. Not absolutely horrid, but not quite right. I also get a mild backfire if I accelerate hard and let it drop to idle when I am in park. I checked my timing and it is correct. This is the 1985 2.8 2wd. It says 10BTDC in the manual, with altitude(about 5200 ft) I have added three degrees so I set it at 13BTDC. This is with the vacuum removed from the vacuum advance module on the distributor.
Anyone care to offer a diagnosis and repair? I think I know, but I won't say just yet.
TIA,
Mark
Please chime in if you can.
Boozebag
Did you replace the cam?
I suspect that you may have to advance the timing more than the factory recommendations. This is a carb engine, yes?
You can usually adjust the rockers to stop making noise.
Any more info on this? I am trying to remember some of your other posts, but my memory gets soggy after a while.
I gotta quit drinking beer...:(
Awww..you ain't got shit!
Jimmykicker goes to doctor...Doctor: "Jimmy..if you drink another beer...you'll die!" Jimmykicker: "Just how painful a death we talking about here doc??"...
If you can remember what I post, even without beer you are doing better than me!!!
I have not replaced the cam, not yet. I intend to in the next several months. I know I can adjust the rockers a little bit. This is a carbed engine. I'll advance it a few more degrees and see if that helps. Maybe take it to 15/16 BTDC.
I was wondering if someone was going to ask about the cam. That was my first thought, maybe the cam is worn down a bit. I think my next step is to actually do a compression test an vacuum test and see if I can get a better idea of the condition of the motor.
thanks for the thoughts............
and yeah, no beer, no fun, no way!
Boozebag
Mad Max: Confucius... why is beer so good?
Confucius: Man not ask stupid question....
Check the slack in your timing chain... that's probably why you need to advance your timing. I am guessing you know how to do this.
Also, you can pull one valve cover at a time and see if you have any "lazy" rocker arms. If one or 2 aren't moving much, then you know your cam is whipped.
I can't count how many toasted cams I have replaced in small blocks. I pulled one that had 4 PERFECTLY round lobes. Funny thing, the engine still ran.
Even though it is not as common for the 2.8s to wear cams, it does happened. Greasemonkeys posted a thread about this.
Modern oils are crap for flat tappet cams. ZDDP additive is expensive, but it sure beats repalcing a cam...:rolleyes:
Hey Mad Max,
I actually just replaced the timing chain. And yeah it was badly stretched. I believe it is the cam is worn. That isn't too bad as I was going to replace it with one of those crane cams you linked to in your performance thread. The bigger concern is what other wear is in the engine.
I'll start with the cam and go from there I guess.
thanks for the help!!!
Boozebag
Man, I am a DUMBAZZ... Yeah, I did make a few suggestions.
Usually, the cam is the worst wear factor in flat tappet engines. The majority of modern engines have roller cams or overhead cams which do not have the same wear factors involved. Flat tappets have big pressure on them, where ZDDP helps to releive the wear on the interface of tappet to cam. Take ZDDP away and problems develop.
Also, most other engine components are similar in modern engines - like psitons, bearings, rings etc. So, usually you don't see other wear problems overall.
If you replace a worn cam, your engine will act like a new unit.
Especially of you install a performance type grind.
Discussion Starter #8
I opened up a Chilton's and Hayne's manual yesterday. My next move is to systematically go through ALL of the emissions controls. I have 14 pages of thing to cover an test/replace. Mostly not very expensive, but a pain. I figure I will learn a great deal about how this motor works too. If it is still rough, then I will be looking at a new carb. Once that is done I feel I will have ruled out all possibilities for reasons of rough idle.
After that is done, I WILL do the cam. The question at that point is do I pull the motor and do the rear main seal too? And, what other considerations will I need to look at when the time comes? Fortunately that is a ways out.
As to the wear on the cam, and specifically the new cam, are there better lifters that can reduce that wear? Is there such a thing as roller lifters? Time to google.
Discussion Starter #9
My google searches showed roller lifters for performance v-8's. They had the same diameter as the lifters in the v6. I would bet they would work if a person could get the correct length push rods.
hmm.......................
I think GEARS has some rollers on his...might ask him what he has.
Boozebag
There is a little more to it than that... You will need a roller cam too. Duh.
You will also need lifter retainers. These keep the roller lifters from turning in their bore and causing catastrophic damage.
I know that some later blocks have roller cams in them (Aluminum head blocks), but I am pretty sure that all 2.8s did not have this upgrade.
I don't know if you could retro fit one either. The later blocks had bosses that were threaded to accomodate the lifter retainers.
I know you were looking for cams... here some more info:
http://www.howardscams.com/chevrolet-6-cylinder/chevrolet-60-v6-28l-31l-34l-1978-1984
1 - 11 of 11 Posts
About this Discussion
3 Participants
Mad Max
S-10 Forum
Full Forum Listing
