Got Snow?
Planning on swapping out my rear lift shackles and was curious hard easy/hard it would be. Should the axle be jacked up a little to releave pressure, etc... Any tips would be helpful.
it should be pretty streight foreward you will only run into problems if you have rusty bolts.
Got Snow?
I have the 1.5" leveling springs and 3" spindles from Fabtech up front and an add-a-leaf in the rear.
Got Snow?
none since i lifted it but i hope to take some next week. Don't worry, it's nothing compared to yours. You hooked your **** up fat.
you will get aproximately 2" if you use the full extent of the shackles, most come with three different holes that you can use. to vary the lift you get out of them.
Got Snow?
Discussion Starter #8
Thanks for the tips. I put them in last weekend. Was easier than i expected. Good Sh*t!!!
