Hello I have a 2001 2wd s10 andnim thinking on installing a leveling kit any pics on how it will look and if it is recommended thanks in advance
Can you proofread your talk to text before you post please? A pic of what you're working on would help.
Just asking for pics or if you recommend installing a leveling kit on a 2wd s10 to lift the front a little
It helps to see what you're working on. It narrows responses that don't apply.
Hard to tell from an angled pic. Are the rubber insulators in place on the front springs?
It looks completely stock. Leveling kits don't exist for 2wd s10's. You'll need to either raise the front with coil spacers or lift springs or lower the back to match the front using blocks or drop leafs, de-arched springs etc...
