Does the left signal stop flashing if the right signal is working?
Have you exercised the hazard switch several cycles to see if that alters the behavior?
Tore into it this evening. The switch is indeed the issue. Got a new one at the parts store and will be putting it in tomorrow.Does the left signal stop flashing if the right signal is working?
The hazard button broke off. I went and got another switch at Oreilly’s. No idea you could replace just the button. But the new one I just bought the button is red too.Just for fun, what color was the emergency flasher button? The originals were red and the replacements were black. The part number is here on the forum someplace. The cost back in the day was less than $25. They are extremely fragile and will break off if not careful removing the bezel. GM has a repair kit that’s less involved than the entire switch. All that’s need is a pair of needle nose pliers to pull the remains of the old one out, grease the new one and push it into place. While I can’t confirm it, I believe a small piece can be overlooked and jam the new switch causing your problem. This is from 1st hand experience. I might have kept my old switch when I exchanged the column for a ‘97 that had a floor shifter. I’ll have to take a look.
