21 - 28 of 28 Posts
Oaktown Trucks
I used some epoxy on my flush tails (not AVS) and noticed small hairline cracks in the plastic after everything cured. I was told the epoxy may have set too quick and I should use "90 minute epoxy". I haven't been able to find any epoxy that sets that slow at the local hardware store. I just wanted to get some details on the AVS glue before I order it. Any info is appreciated.
Thanks in advance!
Doug
Oaktown Trucks
Thanks. My only concern is that the lenses on my tails are slightly curved because they're mounted vertically. When I replace the lenses, I may heat them a bit to give the lenses a permanent bend.
avsontheweb.com
Make sure you heat it slow and cool it slow.
21 - 28 of 28 Posts
