1 - 10 of 10 Posts
In the past two weeks i put a k+n intake, borla xr-1 race muffler with mandrel bent 2.5" piping, accel dist. cap+rotor, accel 8.8mm wires, and bosch platinum plugs on my 2002 S10 with a 4.3 and 4l60e. All computers have stock programming. The fuel system was cleaned roughly 5000 miles ago.
My question here is that whenever I hit the throttle and the tranny doesn't shift the rpm's jump up to where they used to but then drop by 300-500 rpms. If the tranny does shift the motor revs up just fine. Does this sound like fuel issue or just the automatic equivalent to throttling a stick shift that is in too high of a gear? Maybe just the byproduct of less back-pressure??
Secondly if it is a fuel issue would reprogramming the computer eliminate the problem or would I have to upgrade the hard parts of the fuel system.
Go back to ACDelco plugs.
The bosh plugs will actually cause this issue? I did all the ignition upgrades the prior week and it didn't affect anything with the factory exhaust and intake. I've heard of the bosh +4's scorching cylinder walls but i put in the baseline single electrode platinums.
I didn't say that..but I do know that alot of people really hate anything BUT ACDelco plugs. If it ain't broke don't fix it, and ACDelco plugs ain't broke.
Breakin shit
bosch platinum plugs are shit, run the recommended ac delco plugs and never look back
I also have that exact issue on my 02 4.3 with an auto. I am the original owner and it happened since the day it was purchased. I suspect the torque converter but im not sure. If anyone is interested i can make a little video to sow the tack when it happens, because i have wondered the same thing.
Discussion Starter #8
Is the drivetrain stock or modified because I've only had this issue since the upgrades were installed.
Well i bought the truck and drove it home, no more that 30 minutes after it got home I installed my K&N FIPK. Next morning i drove it to my exhaust shop and had a cat back installed (left factory y pipe). I cant recall it happening on the way home exactly or the very first time it happend exactly i might not have noticed as it was a new vehicle to me but I cant remember it not happening.
That all said I can't see how these mods could possibly effect the trany in this way.
I also purchased a Hyperteck PP3 within the first month and programed in "improved shift firmness". I do recall that after i programed it i was paying extra attention to how the truck was acting (seat dyno when you get something new) and I felt it happen. I put the stock programing back and drove around and had the same problem.
So i re-programed it and have 100k on the clock with no trouble arising from this.
Discussion Starter #10
Any chance it feels like the tranny slips when shifting gears through a corner. Mine has what feels like a momentary slip whenever you enter a corner and it shifts. Same thing when pulling a hill slowly. Straight line it has never once had a hiccup.
1 - 10 of 10 Posts
