1 - 2 of 2 Posts
crazy gearhead like woaaa
ok didnt know where to post this i hope someone knows the answer. i have a 93 s-10. she leaks from under the drivers dash real bad onto the floor and is killing my truck. only when it rains hard. i washed it the other day and the faom gaskets by the hood hinges are shot, is that causing it? i am going to pull the cowl off of it and look inside and see if there is a seam that needs to be caulked or somethin, anyone else have this problem or know the solution, my only other thought is maybe the lower windshield seal? let me know. i sprayed the hose into the hole where the hood hinge is then went in the truck and you could see the water ran down. thanks for the help.
caotic
mine does it... tried to seal it up but cant........ gonna have to pull the windsheild and fix it up... body seams are all sealed up and my rear cargo light is sealed up too........so it has to be the windsheild...
1 - 2 of 2 Posts
