Banned
as of now i have 2" blocks in the rear with stock leafs. i was cleaning and found 3" angled blocks. my plans are to mono leaf and the 3" blocks in the rear. i still carry my 4 wheeler in the bed and i don't want to mess anything up by doing the mono. should i keep 2 leafs+ the overload or would i be ok with 1 leaf and the overload? that truck should never see anything over 500lbs, and the quad is only 300 give or take
2LO4BC
My advice, if you are totally hell bent on doing a mono/overload setup, is to invest in some airshocks..that way you can get load carrying capacity to haul your things around, and also still be able to ride low when you want
Banned
i thought about that last night. do the air shocks ride stiff, or does it depend on how much air's in them.
Damn right I'm a maniac.
Keep at least 20 psi in them to keep the bellows from rubbing on the shock body. At low pressure it will ride just like any other shocks. Higher pressure will stiffen up the suspension.
