i want to lay the kit on the ground with 20s .so what all do i need to do in the front.i know you have to relocate every thing on the fender wells
but do you have to tub the firewall and get a smaller brake boster?
I Like Fire....HaHaHa
Search button is right underneath the Forum button. This question is asked a 100,000 times a month.
Gone but not forgotten
alot more than that bro.. Are you gonna tryin use stock arms or tubulars?
Killin' it Kustoms
i have tubular upper and lowers, 2 inch spindles, tubd firewall, metal heater box, and moved wiring harness up 4 inchs. im running firestone 2600's in the front. i ditched my abs, washer fluid resavoir, and radiator overflow. made a intake. moved battery to the bed. and relocated cpu, and fuse box. you need to notch for tierods too. havnt but im on them hard. i think thats about all. i can post pictures if youd like, mines an extended cab thow.
josh
yep yep, i'm in the process of layin kit right not with stock arms and 20's, and its a B***H! i'm amost done now, but if i could go back i would have boughten tubulars. i searched on here like crazy and got all the info i needed. Just start tearing it apart and you'll see what needs to be done.
