can i lay the rear of my 85 s-10 if i use a bolt in c-notch, weld on axle bracket and weld on upper bracket with 245c bags if i am runnin 225/35/18 tires??? thanks guys
245c??
is that a 224c? or a 255c??
Yes you could lay, if you put the bags behind the axle. There wouldn't be enough room to lay out all the way because the bag would compress before the truck layed out.
Smiegal Sampson
would this work for me, doing this with 205/50/15 tires?
no. It you won't lay if you do an over the axle setup and a c-notch. There is not enough room between the top of the frame and the top of the axle.
Post Whore?
slammed is right. the bag is gonna compress before the axle goes up into the notch. i also agree that behind the axle would work.
Smiegal Sampson
well ok then, ill change my plans because that was what i was going to do, but i heard that behind the axle rides like shyt....
I have behind the axle And I think it is a fine ride!
