1 - 15 of 15 Posts
G
Guest
will drop spindals lay the frnt ground effects of an 2000 extreme
I <3 SPARKS
I think you'll do it without em. A guy on here was gonna get spindles, but ended up not getting them and his front bumper nearly drags now I think...
G
Guest
i need to know cause its like 3 inches off ground
G
Guest
thanks clean n low this is for a friend of mine i do all of his work
Lets go RED WINGS
it depends on the wheels dude. right now I have stock x wheels and im not quite layin out my gfx cuz my wheels are rubbing. Im sure with some wheel/tire combos youll lay.
L
Guest
Discussion Starter #9
16" stock x wheels on 50 series and under rubber with spindle's should pretty much lay ... like trickedOUT im layin rubber and wheel wells up front till i pull em ...
is back...
I agree with LEASNIT.... ohioxtreme lays gfx on his xtreme with stock X rims and 50 series rubber. The tires hit the wheel wells at the same time the front airdam lays.
I have spindles and It sits on the down pipe.
i got spindles and notched a arms on 235.40.18
lays
1 - 15 of 15 Posts
