Whem layin frame do u need to replace/remove the gas tank. I got a 98 std cab. Dale
B BIGBOI'S98 · Registered Joined Sep 15, 2002 · 43 Posts Discussion Starter • #1 • Dec 15, 2003 Whem layin frame do u need to replace/remove the gas tank. I got a 98 std cab. Dale
suicidal · Resident ******* Joined Mar 18, 2002 · 11,268 Posts #2 • Dec 15, 2003 it all depends on what kind of setup you want to run. you do not have to replace or remove it, you can get away with raising it.
SlammedDime · Registered Joined Jun 28, 2002 · 13,733 Posts #3 • Dec 15, 2003 :stupid: It does hang lower than the frame, so inorder to lay frame, something has to be done about it.
