My EXTENSIVE custom wiring behind the dash. I pulled it all out tonight to check for bad connections/grounds (still don't think i found the source of the problem)... but i cleaned it all up and took pics while the dash was out. Also, I started working around 8 and finished up around 1... so I pulled the dash, cleaned the wiring up, checked the grounds, some other shit, and put the dash back in... all in about 5 hrs working by myself
by the way, anyone think they can help with my problem? After I moved all the wiring be hind the dash (extending most of the harness... all by soldering and heat shrink) The truck seems to run perfect... but the transmission won't shift. On my guages, my tach and my oil pressure guages don't work. The Oil pressure guage reads as its pegged out, and the tach doesn't read anything at all. I'm sure i'll figure it out eventually... but if you guys think you know the problem i can try it out before i go research for the DETAILED wire diagrams.
