Is there any noticeable difference between these two power wise. Or is the there something else that is better?
If you look at the VOLANT intake system it's still getting AIR to your motor from that small stock hole. The K&N is useing the stock hole and getting fresh AIR from the bottom of the truck. Also the inlet tube of the K&N looks bigger and that kit may give you MORE POWER!!!! remember more air more POWER!!!!!! :thumbup: CHECK THIS OUTMcBride2k1 said:Is there any noticeable difference between these two power wise. Or is the there something else that is better?
