1 - 20 of 153 Posts
I Like 2 Cut Shit Up.
Hey everyone, my name is Justin I'm 17 year old and I have been on the forum for 7 months now. I have finally decided to start a project thread for my S10. I have been doing a ton of research and have done all my homework for this build. This will be my first bagged/body dropped truck.
The truck is a 87 regular cab, short box S10. With a 350 SBC in it. Its SFBD 2" into the rockers. With a custom frame from the fire wall back (2x3x3/16 tubing)
Its laying on a 245/60/15 tire right now. 20's or 22's will be coming.
It will be getting a new cab and box floor and fire wall.
Tons more to come.
There will be lots of updates and tons of pics.
Enough words I know everyone wants the pics so here they are......
They are in a random order.
The way it sits now.
Tire clearance on bed.
Gussets.
folded rockers.
bed floor cut out
Discussion Starter · #2 ·
cutting out the cab floor
rolling the fender rocker
the exhaust off the truck
the frame off the truck that i only took the body
cutting the rockers
plated 1/8
nice and low.
roof height
bracing the cab
parts truck
these will come in handy
my frame
cab mounts
trailer to pick up the parts truck
picked it up for $250 the body is in good shape.
frame gussets
my cat.lol
this is when it sat for a while
tranny x member still needs exhaust holes
shortened drive shaft.
rear end mock up.
ran a little short. lol
working on translation
the truck with the 350.
doing some welding
extra support.
tranny x member
grinder got me.
brackets
frame work
cuts to run wires though
sits now
old shit gone
Right now the body is just sitting on there. I ordered my tubing and it should be in Tuesday and then I can start working on the cab floor, box floor and fire wall.
Well I got my tubing and I got started on the cab floor.
I also pick up some trailer fenders for the box floor.
(they were on sale):tup:
Square-body crazy
Awesome. I kinda got lost with all the pictures though.
00 Xtreme
2 things- are their bushings on the suspension components? it looks like a bolt through a metal sleeve. The only problem with that is when the suspension wants to articulate, the bushing will absorb the movement instead of the plates and/or links. That and the frames transition at 90 degrees will put a lot of leverage on the welded joint, so I'd either put a big gusset in there or cut out that section and put some angles in it.
But kudos for taking this on at 17, thats pretty ambitious!
Discussion Starter · #13 ·
Ya there are no bushings on there right now. Once I get/ order all my air ride stuff I will order link bar ends and do up some new bars.
1 - 20 of 153 Posts
