1 - 2 of 2 Posts
former title junky mod
I just got new rims and tires, well, new to me... I bought them used and the tires are in great shape on 2 and 2 are ok. It says max PSI is 35 when I put 38 in they still look low? Should I put more in is the 38 good?
2 Litre Terror
Radials will look a little low even at the rec. air pressure. Your fine. Try dropping em down to like 35. That PSI is for max load rating. You may find the truck is a tad smoother at the lower pressure.:burnout:
1 - 2 of 2 Posts
