1 - 2 of 2 Posts
Short Bus Anonymous
...about how much its going to cost to get my bridge kit welded in? Also I see people with notches only running a front or a rear bar across the notches? With my truck fully laid out will the bars hit the axle thingy...
Thanks in advance!
Afterhours Admin
Itll prolly cost over $300 to weld the notch and bridge in..it depends on your setup whether or not itll hit that upper bar..like if you have a bolt-on axle bracket on the pumpkin, thats a bit taller than the stock rear..
1 - 2 of 2 Posts
