Project: Sabriel
what did you change? if you only changed the rear gears, you'll have to get your speedo recalibrated.
You will have to get your speedo recalibrated. If it is cable drive you will have to get a new speedo gear for your trans. If it is an electronic speeed sensor you can get a little module that you wire into the speed sensor to adjust for the gear
Depends on how your speedo is driven. If it was cable you can just change the plastic gear for the speedo cable at the tail housing. But since yours is electronic there are 2 possibilitys.
1) check the tail housing anyway If your sensor is still driven off the old speedo gears the you are all set just go to the dealer and tell them the rear you put in and they order you the correct plastic gear for a couple $$.
2) If the speed sensor is totaly electronic you can take it to the dealer and have the computer reprogramed for the new rear end.
A lot of those aftermarket hand held computer reprogramers can also do the job.
