SDimePimpin08
i just used a blowdrier some goof off it took a hell of a lotta time to do but i got all the chunks off i really dont want to have to repaint but where the emblem was it seems to be a little off colored like green and i have a blue s10 when i wet the door that little rectangle where the emblem was will dry almost instantly does it just need to be waxed or what? please help
DOOR'D FOR HER PLEASURE!
probably try wet sanding it, small area is discolored due to sun fade, 2000 grit may werk, jus dont go through the color to primer
SDimePimpin08
ill try the thing is tho i just finished it like 10-15 mins ago and i did it all in my garage it hasnt even seen the sun but ill go n try by wet sanding will it have to be repainted? thanks
either the truck was repainted and they didnt remove the emblems (hence the blue truck with green under emblem) or over time the emblems do not allow the entire truck to discolor, the emblems block the area underneath them
