So i just inherited a s-10 pickup with the 2.2 motor, its a little sluggish to crank up and only gets up to roughly 20 mph. Does anyone know what could cause this? It also has a code for a misfire.
its a 2000 modelWhat year is it? If it's a flex the fuel filter is not $10, but still worth replacing.
Start with a fuel filter, its cheap, it's easy and no matter what probably needs to be done either way it's basic maintenance and should be done every 30,000-40,000 miles. I will say if the line is rusted which these trucks seem to always do by the fuel filter be prepared to cough up another $15-20 for a fuel line repair kit such as the Dorman one.its a 2000 model
fuel filter is a good check/replacement. but from there id rent a fuel pressure gauge and a compression tester. you can get these for a small deposit which you get back upon the toll return, so essentially they are free. 2.2s are known for 'blowing' head gaskets. id pull the spark plugs, and do a compression check. honestly id do this before doing fuel filter. the 2.2 is a good running engine overall, but given the chance and the head gasket will let go2.2 motor, its a little sluggish to crank up and only gets up to roughly 20 mph
The smell may be true but on my 2.2l it made it run great since it was so clogged that it wouldn't get above 2-3k rpm. Also, it'll sound like hot garbage with the factory muffler. I hated every min of driving that truck after gutting the cat, but it solved the not being able to run issue until the frame broke 4-500 miles later...Gutting your cat isn't going to do anything but make your truck run and smell like a garbage heap.
Why not just replace the cat...like you should?The smell may be true but on my 2.2l it made it run great since it was so clogged that it wouldn't get above 2-3k rpm. Also, it'll sound like hot garbage with the factory muffler. I hated every min of driving that truck after gutting the cat, but it solved the not being able to run issue until the frame broke 4-500 miles later...
Because at the time I had no disposable income to pour into the truck. Considering it's fate just a month or two later, it was a wise decision. I learned a long time ago to be very cautious dumping any money into a cheap vehicle, if it's under $1500 or so all it gets are items that solve issues involving not being able to use it. Living in emissions free states my whole life has given me the attitude of "leave it be, remove if broken" when it comes to evap lines, canisters, cats, etc.Why not just replace the cat...like you should?
