1 - 11 of 11 Posts
i just dropped my 2003 extended cab s10 zq8 with belltech drop spindles, and belltech rear 3 inch block kit with 2 degree taper. but it looks like my truck sits higher in the front?? anyone with same application have that problem?
cats taste like chicken
ur coils will have to re settle, it will be a couple days then you will see the difference..
i guess?
thats what i figured about the coil settlein.. someone else told me that too.
if the truck sat level before you lowered it, then its obvious thats its going to now sit lower in the back because the block is 3" and the spindle is only 2" from the factorym some trucks sat level, and others had a small rake to them. did you measure the truck at all four corners before you dropped it?
Discussion Starter #11
it sits at 27 inches at all four corners
1 - 11 of 11 Posts
