sick & twisted
i bought the jtr sbc mounts and have them bolted to the 2.8 mounts, they are bolted through the first set of holes, ive read the 2nd set is for blazers. i was thinking about cutting them to drop the motor lower, my oil pan has enough clearance to fit it, but i was debating about sectioning it regardless. the sbc is in an s10 frame clip, with a ranger body, i really want the motor to clear the stock hood.has anyone dropped the motor lower with these mounts? any pics and input would be appreciated! thanks
sick & twisted
Sweet shit. Thanks Ricky!
For clarification ricky, are you saying use the upper set of holes and cut off the excess from the engine side mount?
I have a blazer and I'm going to be wanting my V8 as low as possible, so I thought I would ask while it's being brought up.
http://www.vicbaggers.com
It's the set on the left, but you knew that..the set of holes on the top & cut off & ground it down smooth..I don't know how to use paint or what ever program that is, or I would circle it.
