1 - 20 of 24 Posts
This is exactly how much rim/tire will be tuckin when my truck is let all the way down the lowest point of my tire and my frame are the exact same amount of inches from the ground in the pics.
"i got that slap"
LaynLo17 said:
look closer at the pics the rims NOT bolted on. its jacked up and leanin in
yea thats what i've been thinking, anyone can jack thier rim up at an angle w/o boltin' them up and have camber out the ass....take some pics of it bolted up and under body pics and prove me wrong...if u do have that much props
bitch
layinbody31 said:
except that the hub is at the same negative camber angle as the wheel...
no not quite, look at the wheel studs
edit~given its a 4x4 itll have more camber than a 2wd but you gotta be more observant ;)
bitch
CandyPaintOn22z said:
its bolted up just 2 lug nuts.
13th pic down, your not gonna tell me theres 2 lug nuts on it. its not bolted on in that pic and its leaned in a lot farther than it should be.
1 - 20 of 24 Posts
