1 - 1 of 1 Posts
I may have Jimmy 7.5 " Posi Rear Axle Problem,:(
Don't need the posi, can I swap the common S-10 non posi unit directly in this case?
I just bought the rear axle to go in my 53 BelAir.:p
I opened up the case and the magnet had some metal sludge (probably no worry there) but also two chips about the size of your small fingernail (not shiny, looks like rough cast finish on the chips (maybe something to be concerned about).:eek:
Can I reuse the ring and pinion and just change out the spider gear setup?
Thanks
1 - 1 of 1 Posts
