Plan on spending the whole day on it.
The instructions are great and the procedure is simple but, this mod is very time consuming!
The nuts that you must remove from the y-pipe are a PAIN! spray as much liquid wrench or penetrating fluid on them as possible.
Take your time on everything and pay close attention to the order that you should remove everything. If you have A/C you are in for a special treat, even less room.
Don't get discouraged.
This mod will be on of the most effective ones that you will make, every mod that you do from now on will be made more effective because of these headers.
Let us know!
Make sure your ratchet set has two extensions and a wobble might be helpfull!
