1 - 20 of 32 Posts
ERRATIC.. erraticclub.com
Either.
How are your bags mounted? What style bags do you have? Where are your shocks mounted? How much of an angle do they have? What flavor of link setup do you have (forward or reverse)
Better yet, have any pics?
The fishtailing your talking about sounds like the axle is shifting from left to right while your driving man. Got any picts of your setup or more detail on it?
i can try takin pics with my cam phone... i know they are gonna suck tho
its a universal tri 4 from fbi (year old) bags over axle, shocks right by the bags.. rs72 and they stay pretty straight from full lift to aired out
let me try takin pics with my phone..
With the bars in front ofthe axle it should be I^I and in the rear of the axle it should be IvI. The widest point of the triangulated wishbone is on the axle, keeps it from wondering fron side to side.
Doughboy
Do you have a track bar to keep your rear end in place ?
dubdS10
If he's got a tri 4-link he wont need a "track" bar/pan hard bar.
We need to see some pics to figure out the problem but I'm going to say the bad ride comes from the over axle setup. If you want that type of setup you should run sleeve bags.
Nate
Beer, Bait and Ammo
word.......
kyle, put the bags on the bars fix the hiem shit junk that you broke and than make sure the links are the same size and everything is Square than you done......or
Blazer-B-Q?
Discussion Starter · #12 ·
hey mike.. im stealin one from shawn.. WHATS THE OPPOSITE OF ABOVE ME?? BE-LOW ME!!!
it was fked up BEFORE i drug through the heims.. im lookin right now into bushings, and putting the bags on the lower bars.. the rear setup is all about to get yanked off and redone anyway.. so the top link bars wont be the wrong way... theres like 3 inches between them on the axle.. (differential bracket)
Discussion Starter · #13 · (Edited)
the front of the top bars are in front of the axle on the frame.. its backwards.. i guess you could call it a reverse tri 4.. but in front of the axle.. wow my friend who welded it is a genious!!
I'm poor
It is perfectly acceptable to have the upper bars closer together at the axle and wider at the frame. IT MAKES NO DIFFERENCE.
Shitty ride is definately the over axle setup.
As I said before, and as Motomullet above this post said, the triangulation of the bars makes no difference.
Discussion Starter · #16 ·
if it makes no difference.. can someone explain the swaying? IT HAS SHOCKS.. isnt this kinda the reason for shocks?????
bitch
you post these retarded threads once a week and people tell you the same thing. post a pic of your ****in setup because somethins not done right, if you dont post a pic we cant help you
+1
Dude, borrow a camera from someone if you have to. I'm sure a friend, parent, sibling, significant other or someone you know has a digital camera that takes pictures worth a damn, so we can see what hell is going on here.
And to answer your question, no shocks will not do anything about swaying side to side.
As i said before, if you have a triangulated upper bar, the widest point with the two joints has to be on the axle, that keeps the axle in line and straight. If all the bars go straight forward then you have to have a panhard bar
1 - 20 of 32 Posts
