Is a 3" "c" notch safe to do to the frame? or stick with a 2.5"?
Thanks. Last does anyone know how tall the frame is there? 4-5"?
The frame over the axle is only 4". I wouldn't recommend 3", but you could go for it if you want, just use a beefy notch. Jason's notch is 2 1/4".
It was going to be a home made notch the guy that is doing my welding said he can make one. So I will tell him to make it beefy maby if he boxed in the back side of the frame?
I want to drag so bad and I am 3" from the ground!!... I also don't wan't to cut up my bed just a small bump in the middle.
lol, yea I was just going to cut a hole for the diff, nothing else I was going to try to be one of the few that can lay frame without cutting a huge hole in the bed :D
Premium Member
cut a hole and make a smooth cover for it?
Discussion Starter #9
all great idias!! I will do it time, But for now I still use this truck for work! And I need all the space I can get.
